Well, certainly true but as you know this has only been in the code for the last 2 cycles. So the are 10s of millions out there just like this. The Canadians were way ahead of us on this.A bigger concern is that the hot lugs above (upstream of) the main circuit breaker are not insulated in this old panel.
It's not a violation (grandparent clause) and does not not need to be changed, but it does present an electrical-contact-injury hazard to anyone working in this panel.
Canadians are way ahead of Americans on a lot of things.Well, certainly true but as you know this has only been in the code for the last 2 cycles. So the are 10s of millions out there just like this. The Canadians were way ahead of us on this.
Good eye, that's plaster and lath.Are you sure it is sheetrock?
Not sheet rock, plaster and lathe using wire mesh lathe.And who cut that sheetrock out with an axe?!?!?!?! LOL
How are you going to pull a new neutral inside that cable?Opened up a panel today and the neutral is not insulated as shown. I presume pulling new neutral is the best option to fix this issue?
Thanks
Well, I see a bonding screw, it has a main breaker, grounds and neutrals terminated on neutral bar and I'm sure not missed by you. Looks like a duck, walks like a duck... but as we know, anything is possible.How are you going to pull a new neutral inside that cable?
I just hope we can presume that's the service panel and the cable is not a feeder.
My thought as well. One might argue that it needs its own breaker but I wouldn't lose any sleep over it.Um, interesting
Look at original pic. I think it's a surge arrestor.
Shouldn't need it's own breaker. And QO and Homeline breakers 30 amp and less are perfect to put them on with other loads because the lugs on those do accept multiple conductors.My thought as well. One might argue that it needs its own breaker but I wouldn't lose any sleep over it.
