radackj
- Temecula, Ca
Ok here is a head scratcher, well for me any way.
210.11 C (2) Laundry Branch Circuits. In addition to the number of
branch circuits required by other parts of this section, at least
one additional 20-ampere branch circuit shall be provided to
supply the laundry receptacle outlet(s) required by 210.52(F).
This circuit shall have no other outlets. However 210.52(F) exception (1) states that multi- dwelling units laundry doesn’t have to be dedicated. My question is this. We are working in an apartment dwelling with laundry on each floor. We have exterior bollard led lamps (6) of them that need power. One of the guys suggested we pull power from a gfi ckt in the laundry, as it is the closest to the bollard lamps. I didn’t think it was a good idea but the Lead is interpreting the NEC to say because it isn’t a single family dwelling. 210.11 C (2) does not apply about no other outlets or in this case tapping onto an existing ckt for other than laundry use. What say you? Someone help clarify this. I don’t see why an apartment laundry needs to be less protected than s single family dwelling.
