Flicker Index
- Pac NW
- Lights
Lumens per watt is a combination of efficacy and efficiency. It's important to not conflate efficacy and efficiency
The theoretical maximum photopic lumens per watt that can be achieved is 683 lumens per watt, and that is the lumens delivered by one watt of 555 nm monochromatic light. A contraption that converts one watt of electrical input into half a watt of 555 nm would produce 342 lumens to one watt of electrical power.
Even if we were to have a device that converts 100% of input to electromagnetic energy within the visible light spectrum, the lm/W varies depending on the spectral power distribution. A watt of deep red or near UV have much lower visual response, so the lumen would be lower.
LEDs (solid state fluorescent lamps) and low pressure mercury fluorescent lamps work similarly, yet differently. If you were to build a "fluorescent lamp" without the phosphor coating, it will glow sky blue due to visible components of mercury lines. The ordinary glass would block the UVC. The light given off by a normal fluorescent lamp is the combination of this sky blue light and whatever the phosphor blend gives off in response to UVC. Commercial LEDs use royal blue to excite the phosphor blend. The white light is a blend of yellow light from the phosphor blend and the blue that passes through.
