ggunn
- Austin, TX, USA
- Consulting Electrical Engineer - Photovoltaic Systems
Lucky you.I deal with a lot of electricians but few if any inspectors.
P=(I^2)RThe book says the answer is 500 watts, please explain how they got that.
In this case the question writer made it easy; for two identical resistors in parallel the combined resistance is simply half that of either one of them.To determine the resistance of two resistors in parallel try using the "product" over the "sum" formula.
Product / Sum in this case is: 10 * 10 / 10 +10 = 100/20 = 5 ohms
Now try using power formula from wheel above:
Power = I2 * R
Current2 (squared) * Resistance = 10 Amps * 10 Amps * 5 ohms = 500 watts
Oddly no one seems to want to give you the actual Kirchoff's law on parallel resistance. Feel free to search Google for a more in depth study, butYes I know all about that , what I didn't know is how to find total resistance of parallel loads. The equation made no sense to me , now I understand it. Thanks for the help
I teach my students as well as time allows and still only about 1 in 5 will retain it beyond the test.I am always amazed at how poorly electrician apprentices are taught the really basic stuff about electricity. This should have been something the op figured out in his head in about ten seconds.
The other issue that just makes me crazy is how few electricians can actually read electrical drawings and understand them.
I agree, too. I have been interested in electronics since I was little. I built "foxhole" and crystal radios when I was six from books I found in the school library, and ran phone lines at home.I am always amazed at how poorly electrician apprentices are taught the really basic stuff about electricity. This should have been something the op figured out in his head in about ten seconds.
