Absolutely, I agree. Wasn't trying to contradict anyone, I just wanted to point out that these options existSimple setups with float control in line with the motor have no delays. They instantly turn on or off when water level causes float to hit upper or lower setting. You need more advanced controls if you want delays in the operation scheme.
If the float has limited travel range like the one you posted appears to have, it pumps X inches of water each cycle regardless what elevation it is placed within the sump.I agree, this is what I used to get the float well above the pump which limits cycling.
View attachment 2561968![]()
That's incorrect. It has a built in OFF time delay so that even when the water level decreases and the float switch is open the pump still runs depending on the time delay setting.If the float has limited travel range like the one you posted appears to have, it pumps X inches of water each cycle regardless what elevation it is placed within the sump.
Gotcha, though it still pumps X inches of water regardless of elevation in sump before switch actuates. After that it depends on time setting as well as possible timing range and volume of sump. Too much time delay and you can run the pump dry, though that probably doesn't hurt most these pumps.That's incorrect. It has a built in OFF time delay so that even when the water level decreases and the float switch is open the pump still runs depending on the time delay setting.![]()
Post #54 clearly set out the situation where the low water level is below the pipes feeding into the sump.Gotcha, though it still pumps X inches of water regardless of elevation in sump before switch actuates. After that it depends on time setting as well as possible timing range and volume of sump. Too much time delay and you can run the pump dry, though that probably doesn't hurt most these pumps.
