Alwayslearningelec
- NJ
- Estimator
I’m trying to do a design for the temp wiring/power to these trailers.LOL
Trailer panels are single phase 120/208v
2 trailers with 60A main breaker panel -Might feed them with 40A. One of the trailers is ours and was told we always feed it with 40A and not a problem.
1 trailer with 125A main breaker.
I am going to have a 250A 277/480v existing panel that we will use for power that will feed a xfrmr. This xfrmr will feed sub panel. This subpanel will feed the trailers.
Working backwards.
Hope this makes some sort of sense. Thanks for the help.
Working backwards.
- The subpanel feeding the trailers can be a single phase panel, correct? I will have (1) 125A and (2) 60A branch breakers( could possibly be 40A) in the panel. What size main would I have in this subpanel. 200A?
- I could use a 75kva xfrmr as that would output 208 amps on the secondary 120/208v side?
- This xfrmr would require a 125A breaker in the existing panel to feed the 277/480v side?
