I still do this for the odd time I use a split bolt. Cheap tape backwards then forwards, few rubber layers, and then cheap tape again. I don't do motors really so ignore not having fiberglass or cambric in there.Before Polaris type insulated terminal blocks were readily available, it was common to do taps or splices of large wires with split bolts or c-taps and lots of tape. The thick rubber insulating tape was often used first with the thinner stuff (i.e.what is commonly meant by 'electrical tape' nowadays) wrapped over it to keep it firmly in place.
I've actually never bothered with the cambric stuff. I've cut miles off though from old old splices.Dont forget the friction tape,,,,
JAP>
Operative words "lots of tape"Before Polaris type insulated terminal blocks were readily available, it was common to do taps or splices of large wires with split bolts or c-taps and lots of tape. The thick rubber insulating tape was often used first with the thinner stuff (i.e.what is commonly meant by 'electrical tape' nowadays) wrapped over it to keep it firmly in place.
If you install the rubber per the instructions, there is no need for fiberglass or cambric under the rubber. The instruction say to wrap sticky side out. It comes right off without sticking to the terminations, if you slit it and spread it open with two pair of pliers.I still do this for the odd time I use a split bolt. Cheap tape backwards then forwards, few rubber layers, and then cheap tape again. I don't do motors really so ignore not having fiberglass or cambric in there.
You're not truly an old timer if you haven't used friction tape on a split bolt splice.
JAP>
Ever run into an old split-bolt connection that was taped then varnished? Taking that apart was Not Fun (IIRC I finally used a hacksaw).
So you're the guy taking a piece of bare #4 EGC and wrapping some tape on it and use it as an insulated conductor.I want to say thanks for your commentaries, and I could say that electrical tape is going to work as equivalent of the insulation. I am going to have in mind that electrical tape has the right characteristics, thanks.
Not all "electric" tape is created equal.
No landed on a breaker.I would say if he's wrapping a #4 bare he'd be wrapping a GEC.....
Jap>
