nuckythompson
- Nova Scotia
- Electrical
Hi there, so I have a GFCI receptacle controlled by an electronic Lutron switch. From this receptacle I plugged a string of LED lights together using extension cords. When I turn the switch off, a set of the LED lights stays lit. With the switch off, I measured 37V to ground at this receptacle. Any ideas what is going on here?
I was thinking maybe faulty receptacle or switch, maybe incorrectly wired. A colleague mentioned that if you plugged an incandescent light bulb into the circuit the problem would go away, but he could not explain why.
Thanks,
Thanks,
