I have a project that is going to be composed of huge luxury type town-homes about 4,500sqft a piece (total for the whole build out is 18,000 sqft). There will be 4 of them in the same structure that is separated by a 2-hour fire wall (so 4 town homes in same building). Based on initial load calculation I'm going to need 400Amp 240/120 single phase to each town-home. I usually provide meter-center-stack for condo/town home layouts but in this particular case the service requirement per town home is high, i have not seen any manufacturer that provides a stacked meter center with a seperate 400amp mains/meters to each town home, (maximum i seen is 200A a meter). I was planning on providing a separate 400Amp service to each town home for a total of 4 separate mains for the building. Similar to NEC figure exhibit 230.2.
My question is and this where the confusion for me comes, does the 4 separate 400A mains need to be next to each other or would it be okay to put them around the building closest to each town home? Also, does the 4 disconnects need to be all fed from the same utility transformer or is it okay to feed them from different utility transformers? I'm considering these town homes as separate structures and it is allowable to have separate service coming in to each one of them because of the firewall between them, is that a reasonable assumption for something like this?
Thank you
Thank you
