I have a 208 nominal, (actual applied voltage 216 Volt) wall pack fixture with 400 watt metal halide bulbs.
Can I bypass Ballast/transformer-Capacitor and install a replacement 120volt/277volt rated LED Bulb? I know that the 208 falls in the 120v/277v rating of the bulb, but I am concerned with the 208v being phase to phase, since the 277v uses phase to neutral. Will that work with the LED driver?
