electrofelon
- Cherry Valley NY, Seattle, WA
- Electrician
Ok we are in agreement that the NEC doesn't require rebar be installed in a footing, I never thought that. I was just saying that their WILL be rebar in the footing and you thus you HAVE TO use it as a GE.Either way it still isn't the NEC that requires the ufer to be installed. For new construction it will almost certainly exist, but only because some other code(s) require(s) it.
