Electrical tips for townhomes built nearby beach area and corrosive environment
Cartoon1
Florida
Electrical Engineer
Hello!
I'm designing a townhomes building (6 townhomes next to each other separated by firewall) a block away from the beach. Any special electrical tips for buildings that are going to be built by a nearby beach from your experiences in electrical construction in these type of corrosive environment and weather swings. Things like installing PVC properly, screws/straps to be stainless steel, etc.
Thank you
Hello!
Thank you
You can specify that the outdoor condenser coils be coated, which are a little more expensive than a standard coil.
Cut down any air infiltration as much as possible. That salt air find its way into boxes and well everything.
No Al wire.
SS 316 fasteners, antiseze
If using RMC, coat all exposed threads with cold galv paint, 2 coats
SS meter enclosures
Penatrox E all connections and threads
Ul listed ground rods these have are copper clad
Standard painted sheet metal enclosures do not last, concentric ko’s rust
Hello!
Thank you
If you so inclined, read “rust” by Mary Roach.
