I need 20kW worth of power. The only easiest solution I have found is to grab power from this existing 200A service switch with 200A fuses. I will be doing a 220.87 load study but I think it has the capacity for it. This service switch is feeding a panelboard which will be left alone.
My question is, can we use polaris connectors inside the service switch to do the tap? There is another knockout on the left side for the new conduit, the new conduit will penetrate behind the service switch into a wall. Is that feasible? can the knockout and
penetration be made without taking apart the service switch? see picture
How long does it usually take to install polaris connectors inside the service switch?
