dm9289
Industrial Maintenance Electrician
- Pennsylvania
- Industrial process repair/ maintenance Electrician
I work in a factory (industrial mill) while doing overhead crane inspection I seen something I thought to be odd.
A large box below the bus and surrounding it with a square hole cut out for wire entry.
This is older bus is there some provision where this could be code compliant. In my opinion no way.
Thank you
Thank you
