Instant Water Heater GFCI protection
td1236
California
Instant water heater is 30 amps 120 volts. There are no 30 amp single pole breakers in stores. Need to run four circuits.
What is the best way to gfci protect the water heaters, can I share a neutral for 2 circuits and use a two pole 30 amp gfci breaker?
Thanks Larry! is there any way to use two, two pole gfci breakers for the four circuit? Would they function correctly?
