LarryFine
- Henrico County, VA
- Electrical Contractor
Is there a harness or strap made to allow me to lean back to free both hands while working on a ladder?
Gemtor Pompier Belts are designed and classified as ladder/escape belts. They are intended for use both as a positioning device for a person on a ladder as well as for use by the wearer as an emergency self-rescue device. Gemtor Pompier Belts are specified by departments around the world and have become synonymous with quality and dependability.
That sure looks like what Johnny and Roy had on Squad 51.
How do you plan to connect it?I bought a fall-suppression strap today, which has about two feet of strap bundled in a length of clear heat-shrink (I'm guessing) tubing as a shock absorber. It's six feet long with two very sturdy clips.
My lean should be more than gentle enough to avoid pulling any of the strap out of the tube. I don't really need to lean back; I just want enough security to not have to lean forward, one arm around a rung.
Werner 6 ft. Shock Absorbing Fall Protection Lanyard C380000W - The Home Depot
For new maintenance or repairs, look to this Werner 6-ft. shock absorbing lanyard. Made of a high strength, polyester web, it offers an energy absorber to reduce the forces of a fall to a safe level. Double locking snap hook hardware allows quick connection. For safety, it meets ANSI and OSHA...www.homedepot.com
Clip it to itself in a single loop around me and the ladder.How do you plan to connect it?
Where might one find such a beast?It's nice to have some adjustment on the lanyard. I use an arborist flipline similar to this with an ART postioner.
Any arborist supply will have a number of flip lines. The ART Positoner 2 ($$$$) that I posted in post #11 isn't really necessary for what you want to do, I only use it because I have one for tree work. Something like this with a prusik cord for adjustment will work just fine. The idea is the get it adjusted so that you can be hands free and still be balanced on the ladder rung. This one will require an additional carabiner.Where might one find such a beast?
My gear in the photo. Belt is a Bashlin with (L to R) Orange Utility Hook, Bolt Bag, Handline Carrier and Tool Pouch added on. Be aware that the belt with tools is about 25-30 lbs. The Yellow Item is the adjustable lanyard. The Brown/Blue is a Fall Restricting Wood Pole lanyard (no more brown straps allowed), just for completeness. Both Lanyards are DBI/SALA. I left my hooks in the truck (very old Klien's) with Buckingham Velcro Pads.I use my pole climbing belt and an adjustable lanyard. It is not a very cheap option, but when you need the gear to climb poles, it is very comfortable as it is made for that leaned back position. I'll try to post a photo of my actual gear later today.
By hooks are you referring to climbing spurs, picks, gaffs, etc.?I left my hooks in the truck (very old Klien's) with Buckingham Velcro Pads.
Yes, technically gaffs, but around here they just call it "belt and hooks".By hooks are you referring to climbing spurs, picks, gaffs, etc.?
Interesting I've never heard that one.Yes, technically gaffs, but around here they just call it "belt and hooks".
