mxlplx00
- Watsonville, California
- Electrician
Hi,
I have a new client that owns a small rental home in a desirable beach community. He's between renters and is doing a remodel. I was called in by my friend "the carpenter" to tie in the receptacles for the gas oven, hood (that are being replaced/installed new) and 2 adjacent countertop receptacles.
This place was built in the 1930s. The whole place was run off a 120-volt exterior meter with 2 20-amp Square D breakers on the inside wall. The wiring is all #12 2-wire cable (romex) without a ground. So the whole place basically runs off 2 20-amp circuits.
Somebody installed a Sylvania/Zinsco 14-space service in the front of the house and ran 2 #8s (120-volt) off a 30-amp breaker inside EMT to now feed the old meter socket. The #8 neutral is bonded to the meter socket and the only grounding electrode off the Sylvania is cold water.
Off of the Sylvania they picked up a 240-volt 30-amp dryer, a 15-amp garage receptacle, a 120-volt 20-amp wall heater and of course the 2 original 20-amp circuits that run the original house wiring.
There's a cloths washer with a dryer (240v or gas) and a dishwasher both on the original circuits (the washer and the dishwasher, not the 240-volt dryer). There's the wall heater in the living room (from the Sylvania panel) as the only source of heat for this 2 bedroom unit.
One bedroom has a receptacle with burn marks (probably from a wall heater).
I know the Sylvania should be changed but on a simple inspection it looks fine. It's on a 100-amp main and has 8 extra spaces.
It would be simple to drop out of the Sylvania with any number of circuits and pull them through the raised foundation and feed whatever. I'm thinking at least 2-kitchen counter circuits, dishwasher and the laundry (4 20-amp circuits). And I could get some Connecticut Zinsco breakers until someone springs for a service change. I told him that the hood now requires a dedicated and that he should supply a space heater circuit or something to the bedrooms but that's out of the question.
The owner really expects me to tie in the stuff that I was called out to do (the new hood, gas oven and 2 ktchn counter recpts) to the existing circuit. After exhaustive discussion he has asked for a quote to run 1 new circuit to the new stuff but what do you bet that he wont take it.
So my question (sorry for the essay, I just need to vent) is am I getting overly dramatic here? Should I just tie it in, take my money and be happy, is there any liability for me if I do, are landlords legally allowed to do this or should I continue to push for the 4-dedicated circuits and (respectfully) walk away if he doesn't go with it.
Thanks
Marc
Thanks
Marc
