Alwayslearningelec
- NJ
- Estimator
Sorry a wiring question. Remember not an electrician so like input from the pro’s.
Not showing verticals in the picture.
MC cable being used.
Separate neutrals.
The square in the middle is 4 11/16” box that a 1” conduit from the panel with 5-1P-20(#10’s) circuits will come to.
I’m assuming a separate 12/2 mc cable for the receptacles for each circuit. So (5) mc cables will hit the box along with the 1”.
Does my layout/wiring make sense?
My concern, which I need to check, is the box size. I may need a bigger box for all (5) circuits. Maybe a 6x6.
Instead of a separate 12/2 mc cable to circuit #8 & 14 receptacles does it make more sense to run a multiple neutral mc cable to the first receptacle(circuit #8) then 12/2 to circuit #14 receptacle? This alternative layout is shown in red.
Thank you.
Separate neutrals.
Thank you.
