Fordean
- New Jersey
- Electrical Contractor
Like to hear what exactly is a definite purpose contactor Which example of its use full load capable? Continuous load?
Same here, often in kitchen fire-suppression systems, for example. Am I in trouble?I certainly used a lot of those DPs.
You, me and about every electrician other than ropers..Same here, often in kitchen fire-suppression systems, for example. Am I in trouble?![]()
Contractors are almost always used in a mfg enclosur, like a NEMA 1 starter, the contractor could be component recognized, with entire enclosure listedI've never heard that before. Do you have a reference for it?
Is there a NEC reference that says contactors have to be listed?
Riddle us this, Batman.If a functionally equivalent part were listed what would it be called instead?
Not to mention contactors.Contractors are almost always used in a mfg enclosur, like a NEMA 1 starter, the contractor could be component recognized, with entire enclosure listed
Still waiting for someone to supply this reference.Is there a NEC reference that says contactors have to be listed?
110.21 is the closest I've found.Still waiting for someone to supply this reference.
Source:UL RECOGNIZED COMPONENT MARK (ALL VARIATIONS)
UL Component Recognition means that UL/UL Solutions has evaluated components or materials intended for use in a complete product or system. These components are intended only for end-use products that may be eligible for UL certification.
Because UL Recognized Components are intended for specific applications, Marks or symbols using the letters “U-L” can never be used in connection with the advertising or promotion of UL Recognized Components. The appropriate symbol for promoting a UL Component Recognition is the UL Recognized Component Mark. Products using the UL Recognized Component Mark are never permitted to use a promotional badge.
Nope, nope and nope. All completely illogical.110.3 (B) and (C)
The issue of Listed vs Recognized is a UL thing, but this sums it up fairly well. (emphasis added)
Source:
If I had my AB or SQ D catalogs I could answer.Still waiting for someone to supply this reference.
110.3 (B) and (C)
Source:
I looked because it kind of seems like i may recall seeing some fine print disclaimer like that once for DP contactors, but my square d catalog says;If I had my AB or SQ D catalogs I could answer.
If a device actually SAYS UL Listed, then it is listed, in this case in whatever manner "Form U1" means for that specific product. So in THIS CASE, Square D has PAID to test and LIST the device, when used under "Form U1", as a truly listed device. But UR (Recognized Component) is NOT the same as "Listed", it can only be used as PART of an ASSEMBLY that is itself GOING TO BE LISTED, by supplying UL with the details of how it will be used, with what, and how the entire assembly will be tested and listed."UL Component Recoginized, UL Listed (Form U1), CSA Certified, CE Marked.... "
Trust me, you do NOT want to have to pay for a Field Evaluation by UL...If a Recognized Component is installed in the field, the only way for UL to verify compliance with a component’s conditions of acceptability is to conduct a UL Field Evaluation on the end product where the component is installed.
HERE is perhaps a better UL document pertaining to this issue. Note that this is a document intended for AHJs...
... is entirely optional for AHJs following the NEC, except where the NEC explicitly calls out for listing. It's a matter of how the AHJ wants to treat 110.3(A), which talks about listing only in a non-binding Informational Note. It also talks about labeling and identification which are things the code routinely calls out as requirements for components it doesn't require to be listed.As a basis for approval, code authorities
look for UL Listing Marks to verify that
products have been investigated for
installation in the field in accordance with
model codes.
But I wouldn't have to unless the AHJ asks for it....
If you don't want to read the entire thing, here is the pertinent part.
