Pretty sure that’s for 0-10volt dimming which takes a certain switch and a cable to go with it.What is the purple and grey wire for on a led dimmer, can i dim the led without using those wires on one led. what about 10 led lights on one dimmer if rated for it?
"What is the purple and grey wire for on a led dimmer"What is the purple and grey wire for on a led dimmer can i dim the led without using those wires on one led. what about 10 led lights on one dimmer if rated for it?
He's asking if, instead of using the 0-10v dimming, can he NOT use the purple/gray wires and instead use a standard wall dimmer."can i dim the led without using those wires on one led."
A little confusing. If you use a 0-10 dimmer and do not use those leads the dimmer switch will only turn lights on and off.
www.haichanglight.com
I see nowHe's asking if, instead of using the 0-10v dimming, can he NOT use the purple/gray wires and instead use a standard wall dimmer.
Only if the fixture is compatible, like these....
Backlit LED Panel Lights CCT Switch UGR DALI/Triac/0-10V Dimmable
Haichang Optotech supply Backlit LED panel light with 20W 25W 40W 60W, UGR<19 available. DALI Dimmable, Triac dimmable, 0-10V dimmable.www.haichanglight.com
No problemI see now
Thank you
I did not see it as harsh. Thank you for clarifying.No problem
Btw...after seeing my post, I don't like the tone. If it seemed harsh or tactless, I apologize.
I see now
Thank you
Don't get confused here. This fixture, like most commercial fixtures can be ordered various types of dimming drivers. It isn't that a single part number is compatible with multiple dimming types, which is whatt I first thought Tulsa was saying.He's asking if, instead of using the 0-10v dimming, can he NOT use the purple/gray wires and instead use a standard wall dimmer.
Thanks. I didn't look too far into the description, thinking that was one I'd looked at previouslyDon't get confused here. This fixture, like most commercial fixtures can be ordered various types of dimming drivers. It isn't that a single part number is compatible with multiple dimming types, which is whatt I first thought Tulsa was saying.
I think you will find they aren't dual rated in any case. They are different drivers and the fixtures can be ordered with different options. I may be wrong, but I'm not aware of drivers that are both.Thanks. I didn't look too far into the description, thinking that was one I'd looked at previously
More diligence in the future![]()
Maybe my memory got the best of me, but I was sure I've seen them and thought the link I posted was the one. I know for certain they are available for LED strip lighting with universal dimmingI think you will find they aren't dual rated in any case. They are different drivers and the fixtures can be ordered with different options. I may be wrong, but I'm not aware of drivers that are both.
Interesting. That is one of the reasons I frequent this site. Always learning something. I had not seen a driver (or didn't pay attention) that has multiple dimming capacity. I am sure that if this one does they have them for other lights as well.Maybe my memory got the best of me, but I was sure I've seen them and thought the link I posted was the one. I know for certain they are available for LED strip lighting with universal dimming
