1000 amp 120/240 single phase service
1200 amp single phase service I installed about 35 years ago. Three phase was an available, but customer did not want to pony up the money for it, and the poco kw rate for single phase was much cheaper.
Yeah I have open Delta 4 wire at my shop/home. When I bought the place in 2015 the commercial rate was actually cheaper, not sure what it is now, I'm afraid to look. Transmission + Distribution charge can get a bit high though if I run something big
I never understood that reasoning
energy charge shouldn't really change, I can see different base charges depending on equipment needed to deliver the service. But at same time how much does it cost them to have a 75 kVA single phase pot on a pole vs three 25's? The 25's are probably one the most common pots they keep in the warehouse as well.
POCO by me only supplies up to 400 amp--120/240 1 phase. I would look at 3 phase to the building 208/120 Y.
As others have stated, use the 6 disconnect rule with your panels. No 1000amp disconnect. Way too much $$$
