- Tennessee NEC:2017
- Semi-Retired Electrician
Saw some that the terminal screws would (supposed to) clamp the wire. There were tons of reviews saying a #6 wouldn't fit in the terminals. The mfg remedied that by putting in instructions to split the wire, making a "V" before putting the wire in!I had a customer supply one of those factory “RV” receptacles and enclosure they bought off of Amazon, real bad quality. Terminal screws wouldn’t hold the wires, they would pop out when you tried to put it back into the too small enclosure. Ended up pulling a MidWest one off the truck and installing it. I didn’t want to be responsible for burning up everything in his motor home if the neutral popped out.
Another problem, and I actually encountered that one, is the KOs aren't actually stamped/cut. They look like they were just in a mold that made it look like KOs. I beat one box out of proportion trying to get the KO out. They now include instructions to use a hole saw or step bit!
