TwoBlocked
- Bradford County, PA
- Industrial Electrician
Help my confusion, please. An open delta/open delta (V/V) supplies 3 phase power on the secondary with 120 degrees difference between the primary feeds. But when I think of a typical 480V single phase to 120/240 split phase transformer, I am having trouble visualizing the real difference. I imagine the V/V primary as the same as a center tapped single phase transformer, without the center tap being used anywhere. And I imagine the V/V secondary as the same as a center tapped single phase transformer with the center tap used as neutral. But somehow the one provides 3 phase on the secondary and the other split phase. Something about two transformers being in series is different than one transformer? (center tapped or not...)
