Irving LaRue
- Warrenton, Virginia
- Electrician Apprentice
Hello Mike Holtians!
My master electrician and I went to a customer’s house to correct issues created by a handyman. Customer sold his house and needs to make corrections per home inspection. So he brought in a handyman to fix electrical issues.
The customer has an overloaded, split bus Cutler Hammer panel from 1979. The inspector pointed out that he had 2 neutral wires under the same screw on the neutral bar. The handyman’s solution was to pigtail a 2 neutrals together inside a wire nut and run the single wire under the screw. There was probably 5 of these pigtails in the panel.
He also twisted a few of the ground wires together and crimped them under a crimp sleeve, then ran a single wire underneath the neutral/ground bar. As you can imagine, this created quite the “bowl-of-spaghetti” effect in the panel. However, there’s now only 1 neutral under each screw.
My master electrician told the customer this wasn’t up to code and needed to be corrected. The homeowner resisted and claimed that he looked up the code and it was ok. I’m not sure what to think about this one. I’d love to hear some words of wisdom and code citations from you all. Thanks for the help.
