- NE Nebraska
- EC
That is the rule for any livestock, keep out of reach. Some can reach further than you may think.The little I've worked in horse barns, I was told to keep everything out of possible reach by horses. Nothing in the stall or close enough to reach over and chew on from the door. We ran PVC overhead and I think we came down with rigid to switch & outlet boxes. Been a LONG time.
Nothing electrical in nature needs to be that close to them other than maybe in working areas where they will be attended while there. Water tank heaters is one the most common exceptions, those you need to just find way to not directly expose what you are supplying with, keep it underground, behind walls, floors, or sleeve it in something pretty rigid, like sch40 steel tubing or heavier.
