Electromatic
- Virginia
- Master Electrician
I have a customer that does research on wheel dynamics. They have a test rig that involves two servomotors each fed from separate VFDs. The system is 480V, 3Ø, Wye (no neutral for the drives/motors). They want to record the energy use of the rig per test run. So far, about the only solution I've come up with is a rather fancy panel-mount meter connected to the conductors ahead of the drives with CTs on each phase. I could give them one setup for the whole rig or two setups--one for each motor. Am I missing a simpler option? They don't really need the kVAr, harmonics, etc. that these meters offer.
I will say I looked at some din rail mount monitors--some that could be direct connected, eliminating the CTs. The problem I see with those is access to reset/zero-out the monitor for each run would involve them being too close to energized conductors.
I'm also looking into getting the information straight from the drives. The problem there is that they are outdated, and the customer already doesn't like or understand much of the software interface already.
Any tips would be appreciated!
