mtnelect
HVAC & Electrical Contractor
- Southern California
- Contractor, C10 & C20 - Semi Retired
And why wouldn't Generac want a place at a $1 billion dollar feeding trough?The California Energy Commission may want to consider allocating funds for charging infrastructure paired with batteries or
backup generators that can function independently of the grid.
Soon EMF radiation will be known to cause cancer in California byt nor elsewhere.In California we are in a reality check. You have Solar, Wind Farms planed higher than the Eiffel Tower 10 miles off our coast, Geothermal, Electric Vehicles, Treadmills that charge batteries, what else ? I bought my home in 1975, and Edison was having power outages monthly. So, I went to Cosco and bought a Coleman 4K generator. I never dreamed that I would have to put it to use so often. On Monday May 15, we have another power outage coming up, a pole replacement. They have upgraded their primaries to 4160K to provide more power. This summer I won't be able to run my AC when the power goes out because you now have EV's added to the load. Then add closing the nuclear power plant at Diablo Canyon. What else ?
During a heat wave, the increased demand from A/C may challenge the grid's generating capacity, but at times of peak A/C demand there is likely to be very little concurrent EV charging going on. My understanding is that the spike in A/C demand is at least an order of magnitude greater the concurrent EV demand. In other words, if we could push a magic button and disconnect all the EVs at the time of peak A/C demand, it would make very little difference presently.This summer I won't be able to run my AC when the power goes out because you now have EV's added to the load.
I'm sure California is going to ban any kind of internal combustion engine powered backup generators sometime soon.
Only in the car. 92 isn't hot really when it's over 95 and 100 it is but we've all become wimps in the last 50 years since central AC has become the norm. I have been hooking up a lot of ACs and Minisplits the last month thoughDid you have to turn your AC on today ? It was reported that Washington and Oregon had a temperature of 92 degrees today.
I'll add I wore jeans and a t shirt not shorts. If you acclimate and tough out the not so hot and slightly warm and cold then the extremes are more manageable.
Cheers, Wayne
Ya I think things aren't stabilized at allSomething is going on with the weather ... We have been getting calls for AC from the coastal cities like New Port Beach.
Then you charge. But like I said, that's going to be a small effect relative to the surge in A/C demand due to a heat wave.So, what happens if your EV needs charging and have an emergency ?
Cheers, Wayne
And that's generally true. Sometimes a pain, but generally true.We are here from the government, and we want to help you.
No no, EV's are going to collapse the electrical grid. For some reason that never happened when AC started becoming the norm in the south, but EV's will surely be the endAnd that's generally true. Sometimes a pain, but generally true.
On this EV misinformation, see e.g. the following news article from during last year's flex alerts due to a September heat wave. The executive summary is that the CEC updates its peak demand forecasts every two years, and for the latest forecast (2021), EVs were expected to at worst be 4% of peak demand in 2030. If you look at how much peak demand changes due to a heat wave, it's way way more than 4%.
Even with mass adoption, EVs only increase electricity demand slightly
EVs will account for 2% to 4% of electricity use by 2030spectrumnews1.com
Cheers, Wayne
Lol. We'll just change load calcs again so now we still are under 200 amps or even 100 amps. Practically this can be done since 3va is a lot and heat pumps are being pushed for WH and HVAC so there might be enough efficiency now. My house hardly ever drew close to my load calc and most people want to charge at night or durring the work day not dinner time.No no, EV's are going to collapse the electrical grid. For some reason that never happened when AC started becoming the norm in the south, but EV's will surely be the end![]()
Seems about right, maybe a little high.Being that Ca consumes about 10 million gallons of diesel per day. And each gallon of diesel is about 138,000 BTUs. Just for easy round figures 1/3 of that becomes useful mechanical energy.
I'm getting that they will need an additional 134,812,692 KWh per day to replace all the diesel powered trucks and equipment with electric.
Number seems too small, I may have made mistakes here, I just woke up and need my caffeine fix
