The electron man
- Nyc
- Electrician
New electrician going into year 3 ,my parents are having an issue in there home
The home has a murry main panel with 2 sub panels one in the basement and one on the 2nd floor, the renter on the 2nd floor said they plugged an ipad charger into an outlet and it sparked and all power went out my dad switched all the breakers on and off in the 2nd floor sub but it did not fix anything so he went to the main and shut it off but then it would not turn back on, now both subs don't have power before he turned the main off the second sub had power he was able to tell sine the utility rooms light comes from the basement sub panel
When i checked it at the line side of the main there's normal voltage im thinking the main breaker is broken but not too sure
What is your guys take on this i know it may be hard to know exactly what is wrong from a post but thanks anyways
