dm9289
Industrial Maintenance Electrician
- Pennsylvania
- Industrial process repair/ maintenance Electrician
Panel had a bonded neutral bar on right side via a bonding screw. There were not enough spots for neutrals and grounds. A bare conductor was ran to left side of panel to an added ground bar, and there were several neutrals and grounds landed there. The #6 bare jumper from neutral to added ground bar I believe is wrong due to the bare conductor. Can the bare wire from the neutral bar to added ground bar be replaced with an insulated one to make this installation OK? My feeling is no without knowing what that ground bar is rated for or is this common?
