junkhound
- Renton, WA
- EE, power electronics specialty
Grand-daughter moved into a house with well.
Power to well (circa 1950s or earlier, revised sometme in the past) is 12-2 wg UF wired for 240 V. There appears to be an abandoned MC coming into the well pit but is dead and cannot trace as buried 5 ft deep.
I added red tape to the white wire in the well pit and main breaker box, etc. which had never been done, etc, etc - some other items such as NM in well pit needed correcting etc, etc. Am not going to go to the expense of running 4 wires to the well pit, will leave the 12-2 UF as is.
The other item is that there is a shed another 30 feet away fed with black and white thru 3/4 RMC. The black to black, the white is tied to ground wire in the well pit, and the 3/4 RMC also tied to the 60ft deep 6" well casing so htat is a very solid ground point.
The NON code part is at the shed which uses the UF ground as return, The RMC is tied to the metal box, but the white is treated as a white although the only connection the main breaker panel white in the house is thru the 12-2 WG ground wire.
Other than being not per code, why is this not safe other than being non-standard?
