Tanelectrical
- Washington
- Government worker
In chapter 225.19 Clearances From Buildings for Conductors of Not Over 1000 Volts, Nominal of the NEC. It states
Overhead spans of open conductors and open multiconductor cables shall have a vertical clearance of not less than 2.7 m (8 ft 6 in.) above the roof surface. The vertical clearance above the roof level shall be maintained for a distance not less than 900 mm (3 ft) in all directions from the edge of the roof.
Further down it then allows a few exceptions to the 8ft rule one of the exceptions is as follows.
Exception No. 2: Where the voltage between conductors does not exceed 300, and the roof has a slope of 100 mm in 300 mm (4 in. in 12 in.) or greater, a reduction in clearance to 900 mm (3 ft) shall be permitted.
My question is does the three feet in all directions of the roof apply to the exceptions? Or is it three feet when it passes over the roof up to the edges ?
