Jim.B
- Connecticut
- Electrician
If upgrading a service from 60 to 100 amp or 100 amp to 200 amp do I need a meter main or is that only for new construction
No the meter main is an alternative service setup, there is no new construction vs old construction. Many people like it because they just mount it to the wall and all the wiring is done.So the meter main is basically only for new construction or if the panel is further than 10 ft from entry
A meter main is not a requirement if you install an external disconnect. I am not sure what you need to know. When you do a service upgrade you can remove the meter and install a meter main panel, or you can install a new meter, if needed, and install a service disconnect right next to the meter. The 2020 nec requires a disconnect outside the building.My issue is I don't know when the meter main is required on a service change or if at all
I'm in Connecticut and I'm hearing mixed responses from people I have talked to. It seems like it's dependent on the AHJ I started my business 3 months ago. I came from mostly commercial HVAC controls. The one thing that has me stumped is this damn disconnect on the outside of the house if I need it or not on a service change
The NEC is silent on this so it's up to the adopted code in your locale.Forget it. I'll just call the building inspector much easier!!
You kept asking about a specific piece of equipment that is never required by the code.No you didn't. You talked in circles to impress yourself The last guy that chimed in was spot on!!!!! This is the first and last forum I will ever join. What a joke
That's should have been your first inquiry. Every state has different amendments and your town inspector will answer your question regardingForget it. I'll just call the building inspector much easier!!
Jim.B, No circles. 2020 Code requires an exterior disconnect. That can be accomplished by various means. A meter/main is just one way to get the job done. AHJ in the locality and any amendments by the municipality/state adopting the codes would dictate specifically what is required and when, and where you are might dictate something other than strict 2020 NEC.No you didn't. You talked in circles to impress yourself The last guy that chimed in was spot on!!!!! This is the first and last forum I will ever join. What a joke
Note that service equipment is a defined term in Article 100.230.85(C) Replacement.
Where service equipment is replaced, all of the requirements of this section shall apply.
Exception:
Where only meter sockets, service entrance conductors, or related raceways and fittings are replaced, the requirements of this section shall not apply.
Service Equipment.
The necessary equipment, consisting of a circuit breaker(s) or switch(es) and fuse(s) and their accessories, connected to the serving utility and intended to constitute the main control and disconnect of the serving utility. (CMP-10)
No Loss on our partNo you didn't. You talked in circles to impNo ress yourself The last guy that chimed in was spot on!!!!! This is the first and last forum I will ever join. What a joke
Really, wow.... I don't have any need to impress myself and I know my faults. I was trying to figure out what exactly were you asking. I am sorry I wasted your time trying to help - oh yeah and also trying to impress myself....No you didn't. You talked in circles to impress yourself The last guy that chimed in was spot on!!!!! This is the first and last forum I will ever join. What a joke
