jaywbyrd11
New User
 - Baltimore Md
 - Electrical Foreman
What would happen if voltage got sent into a non running 3phase Ac generator? Would this cause phase to phase or phase to neutral/ground shorts? Or would nothing happen at all.
			The motor is first started as a slip ring induction motor. The resistance is gradually cut-off as the motor gains speed. When it achieves near synchronous speed, DC excitation is given to the rotor, and it is pulled into synchronism. Then it starts rotating as a synchronous motor.Oct 25, 2020
Synchronous Motor Starting - Electrical4U
I'm not so sure. The rotor would be an open circuit and so might as well not be in the magnetic circuit except for the soft iron. I think the generator's stator coils would behave like a transformer's primary windings with no load on the secondary.Well, with the rotor not moving through the stator fields, the stator windings are just big coils of wire with a little resistance. Fir the most part they will look like a short circuit.
Hmmm, with a brushless generator it might create a current that would blow the diodes. Like putting AC to the DC terminals of a bridge rectifier.I'm not sure the rotor would be an open circuit. The rotor would be a transformer secondary connected to the excitation control circuit. So I'd expect voltage induced in the rotor to be applied to the output of the excitation circuit, and the results of this experiment dependent on the details of that excitation circuit.
-Jon
It's still dangerous and illegal.I know to shut off my main breaker before backfeeding my box, but not every homeowner in my area has a similar understanding of what they are doing.
That's a cute little interlock gizmo. I'll have to see if I can find one that fits my box. If not, I'll make one. Thanks for posting.
Look on amazon, I think they are like 40-50 bucks.That's a cute little interlock gizmo. I'll have to see if I can find one that fits my box. If not, I'll make one. Thanks for posting.
				I don't know what manufacturer you're talking about but SQ D, Siemens, GE, etc... all make their own version as well as a lot of other companies such as Joe and Jon mention.That's a cute little interlock gizmo. I'll have to see if I can find one that fits my box. If not, I'll make one. Thanks for posting.
Any co-generation system. The wiring for backfeeding must necessarily be there.But there is a bigger picture to consider. What kind of distribution system would allow this to happen? ...
I was not aware of these before today. Interesting product. Thanks for the reference.... Kirk keys in such a situation is a good idea. ...
					www.kirkkey.com
