Hi all. I'm working on a job installing a 30kVA 240-480 volt three phase transformer for a clients machine that doesn't need a neutral. The primary is 240 volt three phase witha high leg. I'm wondering if I need to ground the H0 connection on the 480 volt secondary. Right now I have 477/480/470 volts phase to phase but some weird voltages to ground. I have an equipment ground coming in with the primary, an equipment ground on the secondary, and a grounding electric conductor to cold water copper, all terminated on a terminal bar. Thanks in advance for your help.
