Hello, I will be installing a 48 amp 1 phase Gen 3 ev charger on the side of a single family house.
I getting set to install a 60 amp GFCI circuit for it and and 60 amp wp pull out disconnect.
Reading around now I'm seeing from the manufacturer a GFCI and Disconnect are NOT recommended.
I know I had some question installing one in a garage a couple years ago and installed it Not GFCI protected because it wasn't a receptacle and was 60 amp not 50 amp, and did not install a disconnect.
Does the code require me to GFCI protect it and install a disconnect, like lets say a outdoor AC unit, when installing this charger outside?
Thank you.
Thank you.
