SeniorElectricalEngineer
- VA
- electrical engineering
Greetings,
We have a water heat source pump with MOCP of 15A. Would it be acceptable to specify a 30A fused disconnect switch with a 15A fuse in it in the circuit powering up this pump? My biggest concern is someone potentially installing a 30A fuse in the 30A fused disconnect switch by mistake making the installation non-NEC compliant. Any thoughts?
