JBPower
- Lexington, SC
- Designer
Industrial complex with all rigid conduit. What are the rules for rigid conduit connecting to a 1600A bus duct disconnect? The bus is secured to steel beams above with allthread rod and lateral supports, if that makes any deference. Does conduit require a flex or seal tight conduit before attaching to the bus duct disconnect and if so what code is it in?
