TXsparky2023
New User
- Lubbock
- Journeyman Electrician
Hello fellow sparkys!
I’m wiring in a new Leviton relay panel with smart breakers and cat6 switches.
The beginning seems simple. A circuit from a panel feeds into the Leviton panel and then feeds the lights so that they can be programmed for on and off times and dimming protocols. The emergency lighting is also nightlights which needs to have the main circuit wired ahead of the relay panel. So I’m wiring main panel to the battery backup in the fixture and then bringing in the relay panel circuit to the led driver. So this is the SAME circuit but different panel boards. We need to keep the neutrals separate but in the light both neutrals will ultimately be tied together. Has anyone else run across this situation? Much appreciated!
