This question is for those that are familiar with the old school GE bus bar configuration.
I need to get a 2 pole breaker in here. For a 240 VAC feed to a sub panel.
The label diagram specifies only a couple spots available for 2 pole breakers in the panel. (see pic)
These are in the top half. (see pic)
These spots are all taken by the reduced size 2p20 and 2p40, and full sized main 2p100.
Everywhere else I do know that a reduced size 2 pole breaker will not physically go there (at least not across the two stabs to gain 240 VAC.)
I am wondering if a full sized 2 pole 60A breaker would be rejected by the plastic or metal rejection tabs if I replaced the 4 @ 30A breakers in the lower right?
