These panels have the meter at the bottom right, UG feed location at the bottom left with the supply lugs in it. The panelboard section is on the top. The panel is a combo OH/UG, if used overhead there's a metal cover called a tunnel kit which is installed to create a separate compartment for the service entrance conductors traveling from the top of the loadcenter section down into the supply side compartment.That sure sounds upside-down to me. Which way does the door open? Could the interior be inverted?
