Krusscher
- Washington State
- Electrician
If you can see a time the disconnect would be shut off to the well pump motor adding a aux switch to the disconnect would prevent the contactors from coming on and allowing your chlorine pump to run with the well pump disconnect off. running your chlorine coil control through the running contact on the well pump contactor makes it so it cant run if the well pump were to over load or not come in for whatever reason.
