Rick 0920
- Jacksonville, FL
- Electrical Instructor
What does "near" mean in the NEC when worded as something needs to be located near to something else? Why is this left wide open for problems? Is near 30"?
24" 12"? My definition of near might not be yours? Art 210.70 (A) (1) in the 2020 NEC states as a revision no less; "The wall mounted control device shall be located NEAR an entrance to the room on a wall." If I put the bedroom switch 18" from the door because of framing members and then get failed on a final because an inspector does not deem 18" as being "near"!!!! At least they give you a dimension on floor receptacles. They have to be within 18" of the wall to counted as the required number of receptacles. Receptacles on kitchen countertops have to be within 24" from an end of the counter, not NEAR the end???
