I had a couple easy pulls on a job last month, just 12's and 10's in a roomy 3/4 EMTI once had a service to pull, 3ph with 500s 125ft
I showed up by myselfI don't know why
After about 10 minutes of kicking rocks I asked the drywall crew if they might be able to help. They got all 9 guys involved and told me to step aside. I kid you not, it was pulled in 2 minutes
Heck yeah. That's what's up.They did![]()
I was driving a ground rod once and having a little trouble getting it started. I asked one of the workers there to just hold the rod while I got it started. This was before cordless drivers and I was using a fence post driver. The guy that I got to help asked what that was and I told him. He said wouldn't it be better to just use a sledge hammer alone. I asked him to try both and see which one he thought was better. So he proceeded to pound away, trying each way.I had a couple easy pulls on a job last month, just 12's and 10's in a roomy 3/4 EMT
I had arranged for my wife to come by and feed when I got ready, but one of the sheetrockers started using my ladder, obviously not realizing it was mine (several ladders but mine was the only 12' in room)
So I walked over and politely said, "Use my ladder all you want! Since y'all gonna help me pull wire"
They did![]()
And drop the acorn over the rod before the pounding starts.I was driving a ground rod once and having a little trouble getting it started. I asked one of the workers there to just hold the rod while I got it started. This was before cordless drivers and I was using a fence post driver. The guy that I got to help asked what that was and I told him. He said wouldn't it be better to just use a sledge hammer alone. I asked him to try both and see which one he thought was better. So he proceeded to pound away, trying each way.
Pretty soon, his fellow workers came over and wanted to try. It was like a game to them to see who could drive it the furthest. I had to stop them or the rod would have been too low to get my GEC on!
I guess you could say I "Tom Sawyered" them!![]()
I used to do that, but found that buying a larger acorn I can still slip it over the rod, even with the end all smashed.And drop the acorn over the rod before the pounding starts.
Mark
I tighten and tape it onto the rod. Keeps it from sliding.I used to do that, but found that buying a larger acorn I can still slip it over the rod, even with the end all smashed.
I've had to dig out a lot of acorns where they slid down into the dirt as the rod went in. You have to keep an eye on it and keep tightening the set screw. The larger acorn solved that.
Some non-electrician contractors I know have been scolded by inspectors for even touching the wiring even if they are simply pushing it aside so they can get past. Personally I think those inspectors are just being.... Donkey donutsIs it legal for someone without a license or apprentice card to assist in wire pulling? Pretty much just feeding wire into a non-live enclosure.
I have people do this quite often, but never with the inspector around.
Yes, inspectors around here want to see the "factory" end to make sure the whole rod is in the dirt. Kinda nuts, given that I could cut 5' off and pound the remaining 3' in, cut-end down.i typically cut off the mushroomed in, it and the remaining 3’ and acorn goes on no problem![]()
Are those inspectors union officials on the side?Some non-electrician contractors I know have been scolded by inspectors for even touching the wiring even if they are simply pushing it aside so they can get past. Personally I think those inspectors are just being.... Donkey donuts
Rob G, Seattle
I was installing some security equipment in a machine room at an AT&T facility 50 or so years ago. I was allowed to plug in phone wiring to my equipment when there were connectors on the end, but to fasten two wires to a screw terminal strip I had to wait 3 hours for the staff union electrician to come do the job.Isn't that pretty much a "Hey, you! Can you give us a hand?" kind of task?
Only limitation I can think of is some sort of cross-trade nonsense...
