Titan_Master
- The Bad Lands
- Contractor
Hi,
I am looking for any information as it relates to NEC / NFPA codes which address connecting two homes together via Ethernet cable.
More specifically where it calls out doing so is not allowed.
This question seems to come up a lot but I’ve never seen anyone cite the section in the code where it prohibits the same. Hoping any information the forum members can provide which address this issue about the pitfalls of doing so.
A perfect example of discussion I see all the time on the Internet forums is there are two homes. Obviously each have their own grounding system in place. The goal is to connect house 1 network switch to house 2’s network switch via a 10-250 plus run.
If we just assume the correct cable and install depth is in place. The risk I see is the voltage potential (difference) from one homes grounding system which connect / power the two separate network switches.
We haven’t even addressed the dangers from induced voltage from lightning.
Thank You!
Chase
Thank You!
Chase
