If it has OCP then I don't see any difference or problem. I may have misread into thinking it was SE with no OCP in which case I have some concern about it being "hidden".Augie, any particular reason why you would be concerned? SE cable in the soffit would be required to be run using the same rules as NM cable so if those rules are followed is the SE cable run in a soffit unsafe?
