 - Illinois
 - retired electrician
Are those battery powered at the wall device?What about the fancy PoE stuff? Any of them have this function?
Maybe. I've seen some controls that are universal remote style without hard wiring and the remote goes into a caddy. They might need a second wall controller though. Most the automation stuff I've used though is line voltage powered with cat 5 for communication only.Are those battery powered at the wall device?
Not sure about monitored switches with fail safe, but there are definitely wireless remote switches that rely on kinetic energy from the switch actuation and do not require either battery or external power.Then you run into this issue in the 2023 code.
Not sure that there is any device on the market that complies with this.
For those types of switches, the rule does not apply...the rule is specific to "battery powered" wall control devices.Not sure about monitored switches with fail safe, but there are definitely wireless remote switches that rely on kinetic energy from the switch actuation and do not require either battery or external power.
There are several brands from different manufacturers, with the"kinetic" line probably being the most widely used.
Hopefully manufacturers update to just make sure all of these wireless systems fail to 100% on so that this is a moot point, but. . . .
The original 2023 text was:210.70 Lighting Outlets Required.
Lighting outlets shall be installed where specified in 210.70(A), (B), and (C). The switch or listed wall-mounted control device shall not rely exclusively on battery power unless it incorporates a positive means of notification of impending battery depletion.
So this change will eliminate the requirement that the battery powered switch turn on the light when the battery fails.210.70 Lighting Outlets Required.
Lighting outlets shall be installed where specified in 210.70(A), (B), and (C). The switch or wall-mounted control device shall not rely exclusively on a battery unless a means is provided for automatically energizing the lighting outlets upon battery failure.
