Distance of light switch from bedroom doorway
Then you run into this issue in the 2023 code.
Not sure that there is any device on the market that complies with this.
Not sure about monitored switches with fail safe, but there are definitely wireless remote switches that rely on kinetic energy from the switch actuation and do not require either battery or external power.
There are several brands from different manufacturers, with the"kinetic" line probably being the most widely used.
I've been noticing more ceiling fan/light units with a wireless remote in recent years. You don't know they are getting these when you do the rough in. In past you could bypass the light through the controller - especially convenient if it was wired with three way switches since you don't know if it is on or off. Many lately don't have that capability or at least not as easily done as they used to be. The fan needs to use the remote or you have no speed control.
For those types of switches, the rule does not apply...the rule is specific to "battery powered" wall control devices.
Hopefully manufacturers update to just make sure all of these wireless systems fail to 100% on so that this is a moot point, but. . . .
That is an interesting problem to think over. Over the last year or two I've replaced almost all of the lighting in my house with Philps Hue bulbs, and all of them are controlled by battery operated switches in the form of either a battery operated Zigbee switch, or a zigbee Hue Switch Module wired to a mechanical toggle or push-button switch. There is no feature I'm aware of in the Hue app that turns the lights on when the switch battery dies. I believe it will alert you to a low battery though.
Everything in my house is integrated to work together using Home Assistant, and I can monitor switch battery levels in that software, which means I should be able to write an automation that switches the lights on when the battery drops below a defined threshold. But imagine being asleep at 3am and all the lights come on.
A project I've been thinking about recently is to move all of the Hue switch modules to a central location instead of buried in the switch box as my wife and I have been discussing a plan to sell our house in 5 years after our daughter graduates; I don't want to rip all this stuff out, and having it centrally located where someone can easily work on it in the future would be nice. I just looked online out of curiosity, and I see there are CR2032 battery eliminator kits that replace it with a hardwired disk fitting in the battery slot and connecting to either a wall-wart or USB power source. Now that I know that exists, that's exactly what I'm going to use.
A TIA to 210.70 was just issued by the NFPA. If you have link, it will show up there, however, it does not become part of your locally adopted code, unless the TIA is specifically adopted. The new language is shown below.
210.70 Lighting Outlets Required.
Lighting outlets shall be installed where specified in 210.70(A), (B), and (C). The switch or listed wall-mounted control device shall not rely exclusively on battery power unless it incorporates a positive means of notification of impending battery depletion.
The original 2023 text was:
Lighting outlets shall be installed where specified in 210.70(A), (B), and (C). The switch or wall-mounted control device shall not rely exclusively on a battery unless a means is provided for automatically energizing the lighting outlets upon battery failure.
So this change will eliminate the requirement that the battery powered switch turn on the light when the battery fails.
