- Tennessee NEC:2017
- Semi-Retired Electrician
A couple of questions......
If you are doing a remodel, can you mix regular NM with the newer NM-B? The wiring would only be for receptacles that are existing and wall finish would have to be removed to rewire them.
Can you staple #14 & #12 NM to the bottom of floor joists in a basement if there is a dropped grid ceiling?
