new-master
- MARYLAND
- ELECTRICIAN
If thats a service breaker it is 'up stream' from the cable, those terminals are the supply side of the breaker, unlike feeders and branch circuits. Probably an issue with the oxidation / termination of the aluminum wire.
I agree with Larry it looks like the terminal wasn't torqued properly and the black conductor overheated.
Yes, it's Cutler Hammer. We had a load of those breakers failing that were installed in the 80's or 90's. Some don't kill the power when you shut it off. Others the handle will not stay when switched off- it pops back. I don't know why CH has not had a law suit with these breakers. We have replaced over 10 and I bet there are a ton more out there. I know of others who have had the same issue.
Noalox is typically not required unless the installations require. But it’s easier just to use it and not get comments. Know what the code and UL requires and win those bar betsIt did not have any DEOX/Noalax on the aluminum terminations to the main breaker
Is oxygen not gas that has a deteriorating effect on aluminum?Noalox is typically not required unless the installations require. But it’s easier just to use it and not get comments. Know what the code and UL requires and win those bar bets
And are all those oxide films the same conductivity ?Aluminum oxidizes. So does copper. So does steel. So does…..
That reminds me, I need to check my mom’s, hers is that vintage.Yes, it's Cutler Hammer. We had a load of those breakers failing that were installed in the 80's or 90's. Some don't kill the power when you shut it off. Others the handle will not stay when switched off- it pops back. I don't know why CH has not had a law suit with these breakers. We have replaced over 10 and I bet there are a ton more out there. I know of others who have had the same issue.
It’s there, just hard to see.In true forum spirit we have to nitpick things beyond the actual topic. There is a squeeze type flex connector on the lower black NM and I have looked for awhile and do not see a main bonding jumper, not saying it's not there but I can't find it.
The main bonding jumper is a strap that runs under the main breaker. Almost in line with the switch.In true forum spirit we have to nitpick things beyond the actual topic. There is a squeeze type flex connector on the lower black NM and I have looked for awhile and do not see a main bonding jumper, not saying it's not there but I can't find it.
CH uses a finger that attaches to that strap and the neutral bar.The main bonding jumper is a strap that runs under the main breaker. Almost in line with the switch.
Ron
I figured it was there, I was missing it.It’s there, just hard to see.
