The electron man
- Nyc
- Electrician
Hey guys nyc Electrician here, and was wondering if a car garage would be considered an outdoor location according to the NEC
What Larry saidHey guys nyc Electrician here, and was wondering if a car garage would be considered an outdoor location according to the NEC
Even if there is no door ??Outside the garage, yes. Inside the garage, no.
If it's open, like a carport, damp. We use a 45-degree rain slope to determine damp vs wet.Even if there is no door ??
Thanks a lot for your 2 centsIf it's open, like a carport, damp. We use a 45-degree rain slope to determine damp vs wet.
The crawlspace would be outside of the building envelope.How about this, if a building is on short piers like maybe 24-30 inches off the ground, is that crawl space indoors or outdoors?
If the garage has sheetrock, plywood, or the like on the walls and ceiling then nm cable is fine.. You are in NYC so I don't know if nm is allowed but it would be a dry location.Even if there is no door ??
Nm is only allowed for temp power here in nycIf the garage has sheetrock, plywood, or the like on the walls and ceiling then nm cable is fine.. You are in NYC so I don't know if nm is allowed but it would be a dry location.
I needed to see if I could go with bx instead of rigid pipeJust out of curiosity, why do you ask? What is it about being inside or outside that impacts a project of yours? I agree with what the others have said, but their answers might not be helpful in your intended context.
That should not5 be an issueI needed to see if I could go with bx instead of rigid pipe
